Reset password!
Please somebody tell me how to reset the password on my HiFi Rose 250!
My email: bruab2002@yahoo.co.uk
Thanks….
@Bruab
Let me answer to answer your questions.
There is no way to reset your password in Rose.
First, enter the RoseConnect app that controls RS250.
RoseConnect app–>Scroll the bottom bar to the left and select Setting–>My Page
  1. If you are logged in, click edit and there is Change password at the bottom.
  2. If you are not logged in, when you click My page, there is Find ID/Password under the Login screen.
Thank you, unfortunately I should have asked that I need resetting the password for setting up the SMB connection. I did sort it out so……
Bruno
