Restore prevois power state RS 250
Please add in the next firmware update:
Restore the previous (standby) powerstate
after disconnected from the main power.
@aajrose-rs250
Currently, we do not have a function to go to the display you were using by pressing the power button from the standby mode.
After checking whether it is possible to add it, we will add it if possible.
Rosehan, thank you for your response.
For better understanding my question hereby this note:
I connected my audio/TV set via a timer switch for power saving.
Is it possible - after the timer goes to ‘on’ and the RS250 starts - that the RS250 goes directly in the standby mode, not in deepsleep (shutdown) mode.
Now, at the moment I have to activate the RS250 manually with the power button.
@aajrose-rs250
I’m sorry to tell you tha there is no function to turn the RS250 on via a timer when it is turned off.
The timer is only a function that automatically goes to Standby mode (deepsleep mode, not shutdown mode) after the set time.
Yes, as you said, the only way to turn on the power on the RS250 is to press the power button.
Hi RoseHan,
The only possibility is implement a function.
“ Restore the previous (standby) powerstate
after disconnected from the mains power.”
As a firmware update
This function is in most Nas and Nuc available and works fine
in my situation.
Greetings Ton
