Resync delay on rose and Roon
Before I used Roon I had the resync time on my Rose RS130 set to 3000 msec to avoid missing part of the music when syncing with my Holo May dac
Now I use Roon and also in Roon there is an option for resync delay.
Should I set both to 3000 msec or just the RS130 or just in Roon??
@Bitspeed
I’m sorry for late reply.
When playing music through Roon, you must set the option for resync delay in Roon. Even if you set the option for resync delay on RS130, the sound source played on Roon will not be adjusted.
