return button on Rs150b remote control
pressing the left arrow on the remote control returns to the previous song and not to the start of the song
how to simply return to the beginning of the current song
If you press the previous button and then immediately press the forward button, the current song you want will be played from the beginning.
yes which indicates that you have to juggle, the back button does not allow you to return to the beginning of the song
Currently, the remote control does not have the function you requested.
Currently, our software is set to skip to the previous song when you press the back button.
please give the programming codes to Logitech to be able to use a bluetooth remote control
