Rip CD album cover missing
Hi
I am RS150B owner, I have two problem using rip cd function:
  1. after ripped the CD with selected album cover. But the album cover cannot display on right hand side play lists as icons of each tracks on Rose Premium App on iPad. But the screen on RS150B can show the album cover while play the track.
  2. For those new albums cannot found the album cover automatically. I did copy the album cover by both cover. jpeg & folder.jpeg to the album folder under Rose SSD. It cannot show the album cover on both playlist as icon on iPad and RS150B screen.
Please help!
Hello @Georgie
  1. Close the RoseConnect app completely, disconnect your RS 150 and reconnect it.
  2. For album images, front.jpg in the folder where the album is stored has the highest priority.
    In the ripping process, the album cover is not included in the flac file, so in the case of an album cover, it is recognized if you save it in the album folder as front.jpg, folder.jpg, etc.
