RIP CD's directly to NAS
IS it possible to rip cd’s via the RS150b directly to a Synology NAS?
Hello Marc, what have you Ben able to achieve?
Until now nothing. I’m waiting for the delivery of my rs150.
→ Unfortunately, it’s impossible. You can save only to a USB, SSD and external hard drive connected directly to the ROSE device.
hello, i got the same question but for a 250 rs , is it the same same answer
Hi @ROSELOA,
Is there a plan to add this feature? Most of us have NAS and it would be great if we can directly map the network path and rip them directly to the NAS.
Thanks,
Vishy
Why would you ever want to do that? If you have a NAS, presumably you have a computer as well. Ripping on a computer with some decent software (e.g. dbPowerAmp, but there are many others) is so much more convenient, accurate (both for the rip itself and for getting proper metadata, cover art etc.) and fast compared to the very basic functionality in the streamer that the only reason to use ripping in Rose (or really any other similar device) would be if you do not have and do not want a computer in the house.
