I want to connect a Denafrips Terminator II DAC to my RS150B through I2S RJ45
Is the standard RJ45 T-568B layout used or other?
Can I connect the Denafrips with a standard RJ45 I2S cable?
Did it work right out the box without changing pin layout?
You have a link from this one?
