When using Roon radio the Rose RS130 screen does not change screen info about the song played when next song is coming.
Only when you press pause in Roon radio and then Play again the Rose screen changes to the right song.
Is this a bug in the Rose or in Roon?
What you said was echoed on our part. The software team will check and revise the information. However, you can find out whether modifications are possible after discussing with Roon.
