Rose 130 cannot change In/output settings
It dropped my well functionig coax and optical and has locked HDMI as only output.
At the same time it tells me audio interface not connected.
The system update from today did not fix it.
@KaiE
  1. How is RS130–>Settings → System Settings → Audio Firmware Version Information displayed?
  2. Even if you reboot RS130, won’t the input/output settings change the same?
  3. Even if you factory reset RS130, can’t the input/output settings be changed?
  4. If you have tried all of the above methods and they do not work, you may need to contact the distributor in the country where you purchased the RS130 for repair.
Since this issue is not recognized by XMOS, it does not seem to be resolved with a software update.
