Pensate sia possibile implementare una funzione che consenta di visualizzare sul monitor conesso al Rose il display di Roon così da vedere i testi delle canzoni?
I’m not sure if I understood your question correctly.
If you want to watch the video or music playing on RS130 on your monitor or TV, just connect the HDMI cable to the HDMI port on the rear of RS130 and the HDMI port on your monitor or TV.
From now on, please ask questions in English if possible.
Thanks for reply.
Roon has a function to display song lyrics on a browser by an ip address. I ask if there is a function that allows the Rose 130 to view the Roon lyrics by the monitor connected to the Rose 130.
Or whether this feature could be implemented in the future
It is likely that your request will take some time to be supported or may not be supported at all.
@ROSEHAN @ROSELOA Instead of connecting the RS130 HDMI port to my TV, will it work if I connect the RS130 HDMI port to my Anthem AVM 90 prepro/preamp (which, in turn, directs video to TV and processes/plays the audio).
Yes. That’s what I do…
What I’m doing:
- Rose device connect to external display for showing here the metadata
- adding on the display on another HDMI in a old chromecast and using this as Roon display
→ then I can switch between both HDMI inputs and the second one will show me lyrics etc.
Please confirm: If I connect the RS130 HDMI to my preamp, my preamp receives the video with audio embedded (thus, permitting my preamp to sent the HDMI video portion to my TV and play the HDMI audio portion.
Please confirm this is true.
Yes, I have 2 different inputs configured on the AVM90. One which uses HDMI and the other which uses digital coax. Also in the AVM90 you can configure whether to use room correction and the internal DAC.
Thanks for the confirmation. The reason I asked: on another track, a user said AV is in the HDMI stream only if the HDMI is connected to a TV and if the HDMI is connected to a preamp then only the video is sent without audio.
I am please to here that both video & audio is sent to a preamp’s HDMI.
