When I start my rose130 it say there is an update from 4.17.04 to 4.17.05 system version.
After download and update the rose remain with 4.17.04 system version.
Everytime I start there is this situation and every update don’t go.
Currently, the latest software version for RS130 is 4.17.04. Version 4.17.05 does not exist.
Please check if the update pop-up appears even after factory resetting your RS130 and let me know.
Hi, I follow your suggest but the problem is still here.
Regards.
@pcbr
Please tell me your ROSE ID.
RS130–>Settings–>System info–>ROSE ID
We will verify your device via ROSE ID.
We checked and found that you were classified as operator software and not a user. We have classified you as a user and this pop-up will no longer appear.
