I will be taking delivery of a 150-B in the next few weeks my question anyone using i2s if so what brand are compatible with the Rose i2s pin out ?
My plans are to use a Merason Dac 1 , the i2s pin out of the Merason is compatible with Rockna / PS Audio .
Thanks for the reply, I have found Rockna and PS Audio pin out I’ve been using i2s with Rockna server and the Merason Dac hopefully I can have the one end re-terminated with the j45 , I’ll just have to ask a cable manufacturer.
