Hello fellow rose 150b users, I am planning on buying a playback designs mpd-6 dac. I am reading that some people are having issues on the forum( Dsd dac). This is a expensive dac around 16k, converts all pcm to dsd. My question : Is their any compatability issues with the 150b and playback designs dacs? Is it a smooth handshake between them? I’m planning on using USB. If it won’t function right then it’s good to know before I purchase. Thanks in advance!
As you can see in the table below, when connecting the RS150b and DAC via USB, the supported DSD values differ depending on the DAC’s specifications.
