I have experienced several times that my Rose 150B changes IP adress by it self.
Is there anyway to prevent that from happening?
Thanks in advance.
Thanks in advance.
I think the router can change IP of device (DCHP), but not the Rose
Maybe, I do not know how the hell to make a static IP adress
What is wrong with dynamic IP?
You can check if your router supports this function. Look for “router dhcp mac address reservation”
Edit:
For example with a netgear router:
How do I reserve an IP address on my NETGEAR router? | Answer | NETGEAR Support
Really easy…
Routers will change IP as well when you power them down sometimes. Maybe due a disconnect, IP keep changing.
But am not even sure. These days.
