I have placed an order for a 150-B with an expected delivery mid May . I currently use Rockna WaveDream Net server and have two dacs Rockna WaveDream and Merason Dac 1 both Mearson and Rockna are compatible with each other’s i2s pin outs .
I would very much like to continue using i2s especially since of a recent commissioned i2s cable build for the North American distributor of Rockna .
Most other i2s cable offerings apparently according to the distributor are mediocre by comparison .
I will have to convert one end of the cable to Rj45 for the output of the 150B , anyway I think this should be no problem.
Note I did ask this very question recently here on this forum however upon finding pin out photo comparing photos I cannot interpret .
My question is pin compatibility, PS Audio Rockna , Denafrips including many other brands use the same pin arrangement I wonder if Rose adapted to this also .
Before I use any outboard dac I will thoroughly listen to the 150-B on its own .
