ROSE 150B not powering up
My 150B does not power on after about a year’s use. I understand that there are 2 fuses in the 150B. I checked the one close to the power cable and it looks good. Would anyone know where the second one is and how I can check it, if busted? Or should I send the 150B to an authorized dealer to check it? I live in the Philippines and bought the 150B in Singapore in late 2023
@Bobby
Seems like the LCD should be replaced.
Please contact your distributor to get LCD replaced.
Please contact a distributor in the country where you purchased the RS150 for repair.
@moderators; this appears to be a increasingly concerning problem with both the 150b and 130 models. Please address this issue publicly so we can better understand if many, some or all of these units are prone to this issue.
agree with duffer5. I need to have mine replaced the internal board but it was under warranty.
Thank you for reply. I will have to call Singapore Hi Fi Rose retail shop to check on availability before I send the Rose from Manila.
