Rose 150B - repeated restarts when selecting digital inputs
Hello HiFi Rose Support,
I am experiencing a problem with my Rose RS150B running firmware version 5.11.08.
When I select any external digital input (OPT, COAX IN, AES/EBU or USB IN), the device immediately restarts. This happens even when no cables are connected to the inputs.
In the case of USB IN, the device sometimes restarts twice before returning to normal operation.
After restarting, the streamer works normally and plays music from Tidal and Qobuz without any issues.
A few days before this problem appeared, I also experienced intermittent disconnections between the Rose and the mobile app, causing music playback to stop. Pressing the rear reset button temporarily resolved that issue. Unfortunately, the problem has returned today, and the connection keeps dropping again. It is definitely not an issue with the internet service itself.
I have also tried disconnecting the power cable for several minutes, but this did not solve the problem.
Could you please advise whether this might be a firmware issue with version 5.11.08? Is it possible to reinstall the firmware or downgrade to an earlier version?
I would appreciate your assistance.
Best regards
Kris
