Has anyone encounter problem when connecting their Rose 150b using coaxial to naim n272. Somehow the Naim could not detect any signal from 150b but no problem from other streamer
Appreciate any suggestions
Jeff
Jeff
First of all, I’m sorry for the late reply.
We were away last week to attend a hi-fi audio show in Germany.
We currently have not confirmed any problems with Naim products and RS150b coaxial connections. You said that there is no problem with coaxial connection between Naim products and other streamers, but do you have problems when connecting with other products through coaxial connection with RS150b?
If you don’t have a device to check, ask the distributor in the country where you purchased the RS150b.
The link below is the list of our distributors.
I have brought back to the distributor and they are also perplexed as to why 150b refuse to send signal to naim n272. They even ask me to bring my Naim to check with their other source and it works fine…
They have written to you and have not heard back
Did turn the out on?  Or off and on?
Am going use the coax from the 150B soon with aavik. I hope I dont run into the same issue
Yes, we tried everything. Now just waiting Rose to revert
Yes, to bad… Rose is soo buggy…
1 more thing you can try is hit the USB output. The DaC will shut off. Then hit the coax connection again. DaC will turn on again.
I have no trouble with the update Rose did. Am sick off Rose products
Try that. Nothing changes. Hope you have better luck than me
