My Rose 250A as a streamer optically connected to the new Rose RD160 causes problems, noise in the mids and slight whistling in the highs. The Rose 250A alone sounds wonderful. Both variants go directly to the power amplifier … Any idea?
What happens if you use a different source for RD160? Or maybe try a different connection from the 250.
Thank you BorisM. USB connected and/or PC as Source, same problem.
Odd, but seems to point at a bad RD160 then.
