The installation does not want to start. Currently 4.15, latest 4.6. I have a notification that 4.15 is the latest. I reset the device and nothing. Pls help.
glinek1979@o2.pl
So what version is your device on? 4.15 is the current version, isn’t it?
Yes, I have a lot of problems, rose is not stable
4.15 should be reasonably stable, and currently there would not be anything to update to.So is your device on 4.6 or 4.15?
My device is version 4.15. It’s strange that I can’t update
What would you expect it to update to? 4.15 is the current version.
Last I checked, 15 is greater than 6, and October is later than May…
Also, Rose has a whole section in the forum for announcements, and all firmware releases are posted there.
OMG. Im blind hehehehe. Thx
No problem. You should be all set for now.
My rose had more problems. I got a new one. Thank you for your help
Good luck! Hope net one works better.
