Hi
I’m new here and just wanted to say hello
can someone tell me from shazam on its own the title can be displayed without pressing the button
Greeting Jorg
Hi
Greeting Jorg
When playing music, the title of the played song appears at the top of the RS520 screen.
Do you want to set it to go to the playback screen without pressing it?
If that’s your question, it’s currently not possible.
Hi
I meant when the radio plays a piece of music that it automatically displays the cover and the title,
without confirming anything manually
greetings joerg
Unfortunately, currently there is no setting to automatically display music titles and information when playing a radio channel in the RoseRadio app.
We will check if it is possible to add later and add it if possible.
Is there any news for the automatic cover display?
So far, there is no function that can automatically display the album cover when a radio channel is played in RoseRadio. You need to click the music search button in the lower left corner.
Too bad, pretty much any cheap device can do that (e.g. Arduino) and it only costs a few cents
