Dear Hifirose Support,
I am a new owner of RA280 amp and i am writing to seek support on the connectivity issues when using Rose Amp Connect app in my home wifi network.
Background
- able to download and install the Rose Amp Connect with no issues (iPhone 12 promax)
- able to register the amp into the homewifi as per manual instruction.
- when the amp is ON, able to communicate with the device on its setting and status checking.
Issue
After switching the device to OFF, the Rose Amp Connect will never able to detect the amp no matter how many times it scan the network. If i switch on the amp via the remote control , everything is back in control, until i switch if off.
So is this the issue with the app or something else need to be configured in the wifi ?
My house wifi is powered by Tplink Deco and the amp has been assigned a fixed IP with 2.4ghz wifi.
please help. thanks. KL
