So the issue isn’t “Open Source” vs “Closed Source”.
The issue is that when you have an external wi-fi / bt module, you need to have the specific drivers for that unit, ready to load at startup. So Rose has to then have a list of devices and their drivers already set up in their OS.
You also have to remember that Rose is a Korean brand first, then global. Its not something like Eversolo which was made for the global market, not to mention most of the dongles are made in China.
But even there… they provide a built in mini board for wi-fi and bt. So no dongle.
Rose did this w the RS451 which I suspect is what they are going to do moving forward.
I wish they would pull a couple of engineers to look at grabbing a version of linux focused on audio and then go that route… but I don’t see that happening. Its a huge lift.
If you look at the RA80, there’s no Internet connection, and the only digital thing is a USB port which I suspect is only for firmware updates.
In terms of design decisions. They could have left the RA80s a bit bare bones w no large optical display and then tie it more to the RS451. The display is a bit polarizing and to be honest… if they don’t fix the VU meters… its going to get negative reviews.
