Rose Connect Android DB Rescan Missing
In App Rose Connect
Setting > Media Library >… there is no DB Rescan function. I
@Ben
When you click the three-dot icon on the right side of the storage in the media library, you don’t see DB Scan?
DB Scan or DB rescan have the same function.
@rosehan ‘A picture is worth 1000 words’… Can you kindly SHOW it with a screen copy please ?
Hello ROSEHAN
in the 3dot menu i can see functions
add DB
delete DB
@ZABOKS @Ben
Depending on your DB status, it will be displayed as add DB or rescan DB.
@ROSEHAN Thanks ! There are so many features, menus and options in your GREAT products…
The same logic as in the audio player ! Thank you for helping out.
Hello ROSEHAN
yesterday i tried again with a new folder/album copied to the RS520 internal SSD.
There is no change in the Rose Connect App but in the RS520 i can see a change of the button to rescan the DB.
It seems that the Rose Connect App does not recognise the new music data.
