Am I able to change the TV video output with the app instead of going to the front upper corner of the RS150B screen?
Yes you can. In the IOS app, you must click on the small icon of the video that is at the bottom right of the screen and then turn on the tv by clicking on the switch that is now appearing on the upper right corner of the app. See image bellow.
With the Windows app, the switch is at the upper right corner of the video.
Hope that helps
François
Thank you for the reply. That would make perfect sense, but unfortunately my app doesn’t have that feature.
You have to start playing a video first, and then follow my explanations.
Found it! Thank you…much appreciated!
And how about the Android app ? Is it possible to switch there also ?
I haven’t found it there but it has been a while since I tried. I gave up playing video when I couldn’t find it in the app.
