Rose Connect crashes when logging into Qobuz
Hi, I just bought an RS150b. When I open the Rose Connect app and try to login to Qobuz it crashes Rose Connect.
If I enter the wrong Qobuz password or user name and try to login, it doesn’t crash the Rose Connect app. This only happens if I enter the correct login information. Please help!
Please check the message.
Hi, I am having the same problem
