I’m new to Rose Connect with my Rose RS130.
I have copied approx. 300 CD’s to an internal SSD via my laptop PC and all appears to be well.
However, my Apple iPad with Rose Connect installed does not show all of the CD’s.
What do I need to do for my iPad to see all of the files on the RS130.
Is this problem only on the iPad, or would it work okay without any problems on an Android pad?
Please check a few things.
- Can you see a list of 300 CDs stored on the SSD on your RS130?
- To view music files stored on your SSD through the RoseConnect app, follow the steps below.
RoseConnet app–>Music–>Folder–>SSD
Yes, I can see all 300 CD’s on the RS130.
Also, if I follow the path that you suggest I can also see the CD’s listed within Rose Connect as a written list.
I had hoped that I could see a list of albums displayed by their cover art?
