This problem is noticed with Rose Connect version 4.5.2 on a Windows PC. When logged in and streaming Tidal, the data rate and bit stream type often changes from a high resolution FLAC bit stream as shown…
to then show as an aac type stream with 96kbps bit rate, which isn’t even a format or rate at which Tidal streams! Once this starts happening, all subsequent streams on Tidal show as aac 96kpps, and nothing you can do will change this.
The aac 96kbps also shows on my RS520 unit’s display.
Only way I have found to clear the issue is with a factory reset of the RS520. I used to be able to clear the issue by choosing the Rose Store on the RS520, and Tidal/Clear Data, but with latest 4.6.07 software release, that method doesn’t clear the stream rate issue anymore.
Is this a bug and has anyone else experienced this issue?
Will this be addressed in the next Rose Connect release?
