In the appstore I found 2 applications rose connect and rose connect premium, which one is correct and what is the difference?
Below is the RoseConnect app you need to use for each device. Please use it after downloading the app suitable for the Rose device you are using.
RoseConnect Premium : RS150 / RS520 / RS250 / RS201
Rose Connect : RS301 / RS350
Rose Connect Amp : RA180
Thank You for Your help
Hello. You have to imporove this app. Searching for artist sometimes shows to view the albums of the artist and sometimes not. It’s very comfusing app despite that the Rose 130 that i have sounds like masterpiece.
Currently, the RoseConnect app is continuously being improved.
- Can you take a screenshot of the phenomenon in which search results do not appear when searching for an artist in the RoseConnect app and send it to me?
- If you look at the picture below, when you search for an artist in the RoseConnect app, the first list that appears as a search result is Playlist on Rose. If the search results are not in Playlist on Rose, the search results will not appear. If you swipe the search results category window to the right, various search results will appear.
