Sorry meant Rose Connect
Ah, OK, makes sense. Roon has been one thing that I’ve never had any issues with with Rose.
Does this mean you lose connection when using the Android RoseConnect app?
Or is it impossible to connect from the beginning?
Please describe your symptoms in detail, including photos.
I lose connection when using the Android Roseconnect App. and it happens very often.
Sometimes it just doesnt connect but mostly it connects but frequently looses connection.
Also even when connected there is a lot of lag in commands issued on Roseconnect app and them actually taking effect on the RS520.
This is not at all seen in Roseconnect app on Ipad.
I’ll capture some photos /videos and post.
Does the connection get disconnected when you press a specific button or icon in the Android RoseConnect app? Or does it just disconnect while in use?
Currently, we are not experiencing this symptom. We’ll take our time and check.
