Hello Madam Hello sir.
Since its release last year, I dreamed of buying the HiFi Rose RS520, seduced by the innovative approach via its large touch screen and the announced hi-fi quality.
The dream came true I bought an RS520 and I have been using it for over a month and a half.
Unfortunately I would like to express my disappointment for a device costing more than 3500 Euros.
The software of the RS520 pink hifi is not mature.
There is a connection problem with the internet network which is very disabling whether the ethernet connection is made by cable or wifi. Listening is very frequently interrupted.
My configuration and context is as follows:
1/ Latest software and firmware version of the RS520,
2/ No internet speed problem at home (fiber optic connection),
3/ Using TIDAL HIFI+ with my MacBook Pro works without problems (no listening interruptions),
4/ Use in Europe (France).
Defects observed with the RS520:
4/ Connection with TIDAL or web radios frequently interrupted (internet connection problem whether wired (RJ45) or wifi) and connection problem with the Rose_Connect application.
My problem is not unique, many complaints in this direction appear on your HIFI Rose site.
This is without a doubt a software/Firmware maturity issue of the RS520.
No need to invoke a reset or reload of current software/Firmware but please be honest with us, your customers: Be frank in recognizing the problem and reassure us by telling us that your technical teams are working on this defect and specify When do you expect a fix?
Thanking you for your sincerity.
Best regards.
