Rose Hifi RS520
I am thinking of this device.
But has it tone control control or EQ now with Spotify connect or not ?
Does it have the vu meters with line, aux in and tone control or EQ with aux, line in ?
For example for a turntable ?
Does it have something like radio airable or vtuner, or tune in ?
And is it a big step up for the internal amp from the RS201E ?
Does it sound warm and with enough grip.
So bass ?
Thank you for your response.
@Arno
We are here to answer your questions.
  1. Supports VU meter or EQ for line and Aux input on RS520.
  2. We support our own developed radio app. It supports radio channels from around the world, and you can add any radio channels you want.
  3. RS520 is a higher-spec amplifier than the amplifier built into RS201.
Hi, perception of sound is obviously subjective. And naturally your speakers will play a big role in this. For me, I was really surprised at the excellent sound quality this unit produces. When I switched to RS520 I also upgraded my loudspeaker cables. End result: more bass and very well defined at that. Impressive clarity and separation. Very happy with purchase decision. Would recommend.
NO, it does NOT have tone control or EQ with Spotify connect - very unfortunate.
