I received an update for the Rose One app via the Google Play Store. Since the update, I am no longer able to connect my RS151 within the app. App version (1.0.40.6)
It’s quite frustrating…
Thanks,
Fred
Thanks,
Fred
When you open the app, can you check for updates?
Do a full power boot on the RS151?
Restart the app?
I’ve tried everything to connect the RS151 in Rose One, but it hasn’t worked since the last update. RoseConnect Premium works.
Thanks,
Following this morning’s update to the Rose One app (1.0.43.5), the app is working again with my RS151.
Thanks,
Fred
My iPad tells me the latest version in 1.0.42.1. Odd.
In Android the 1.0.43.5 version appears but, when I updated my Samsung tablet today at 11:00 (GMT +2), Google Play did not show it. I have known its existence only from @fremdg101 message.
I installed the latest software update on the 151. I updated the Rose One Connect app too. The IP address reverts back to old address. I removed app and reinstalled. It worked once and the IP address reverted back. Any suggestions?
To help us better understand the issue, could you please answer the following questions?
Please check the IP address of your ROSE device by going to:
ROSE device → Settings → System Info → Check the IP Address
The IP address of your ROSE device and the Wi-Fi IP address of your phone should match in the first three number groups.
Example – Correct:
ROSE device IP Address: 192.168.4.44
Phone IP Address: 192.168.4.33
Example – Incorrect:
Phone IP Address: 192.168.6.33
This information will help us investigate the issue more accurately.
The Rose Connect app update solved the problem
Reboot your phone?
Reboot or unplug your device for 15-20 seconds and then plug back in.
That usually helps.
Or do a factory reset.
Are you using DHCP on the Rose device?
Can you set up a static IP address on the Rose device and make sure that its outside the range of your DHCP address block or reserved for the device itself?
