ROSE OS experiences with iOS and Android
I’m using the German Versions in Germany. Everything i write is related to that.
About the app in Android:
Minor translation errors, crossfades of different texts do not make it clearer.
At least I can hide the areas I don’t need (e.g. Qobuz, Tidal) in the access menu. Unfortunately, this does not work for any playlist recommendations from Qobuz, Bugs and Tidal users that are displayed everywhere.
In the radio area, KOREA is always displayed as the country by default, which must be set to Germany each time.
Any solutions available?
About the iOS app:
I also use this one and it is plagued by significantly more errors.
Unfortunately, the above-mentioned areas cannot be hidden here. Many more translation errors (“Rosenheim” which is a Bavarian town instead of “Home”)
Sometimes only a few Korean characters in the radio level for an hour.
Improvement has already been promised on these points. When can this be expected?
translation errors
→ We plan to overhaul it in its entirety, but if you point out that something is wrong, we will fix it sooner.
hide recommendations
→ Sorry, no plan for hiding recommendation yet.
→ It will be fixed soon, if the last channel you listened to belongs to Germany, the next time you turn it on, it will be turned on in the Germany.
I apologize for any inconvenience.
Hi Support,
I’ve always this Korean message appear on the unit and Android app even though my default language is set as English. It’s annoying!
It will be changed in next update, sorry about that.
I add to the other comments. A complete “cleanup” is needed for the UI in other languages. I have asked for the removal of “Bugs” because of its inability to be used and because it is slang for a defect in English. I was told to remove the app. I’ve already done that but the hard coding of the UI has “Bugs” in many menus or choices. What I was asking for- and this takes an edit of the UI- was for the removal of “Bugs” from any mention in the UI.
Perhaps this will come in the promised UI rewrite. Any estimate as to when this will be available? Also, will the Internet radio function update come at the same time?
I’ve reviewed the specifications for the upcoming RS 130 and they are stunning. It will be the most advanced Transport out there. Hopefully the software will be in the same league.
