[Rose Platform 4.0] [OTA] SW Ver 4.0(Rose 4.0.08) OTA Release
Hello @ROSELOA ,
If you may please help me out, i’ve been trying to update my rose device and keep getting the “ERR_CONNECT_TIMEOUT” error. I also am not able to use my applications due to
  1. ROSE ID: 0B97F1
  2. REGION: UNITED STATES
  3. EMAIL: jrb9027@gmail.com
  4. MODEL: RS250
Please advise how I may update my device. Thank you so much.
Would you check the message?
Rose ID: 0B97B1
Region: USA
Email: enriquezjune25@yahoo.com
Model: RS250
I was able to update to the new software just a few hours ago but still wanted to know how to troubleshoot my unit in the event it happens again… thanks
Hello June,
It was error from here ROSE server, for users in USA.
I apologize for any inconvenience.
  1. ROSE ID : OB4520
  2. Your region The Netherlands
  3. Your email address: marcelzeilen@gmail.com
  4. your ROSE device model ROSE RS 250
Would you check your email?
Hi @ROSELOA ,
I am having the same problem with new unit, right out of the box. RS250 won’t update. Get the ERR_CONNECT_TIMEOUT on/off. Then (when I believe it should be finished updating) it says “Checking the package. The device is going to reboot” - which is eternal! I unplug the RS250 from the wall… Wait… and plug it back in. Things work pretty well then, but NO Update! Can you help? Just bought this unit.
ROSE ID = 0C87D5
REGION = USA
EMAIL = jpaussa@comcast.net
DEVICE = RS250
Hello SoulshineJohn,
I’m sorry about the issue. Have you tried update with WIFI or ethernet?
If you’ve tried with WIFI, would you check if it’s the same with ethernet?
The ethernet worked! Had been using WiFi. Thank you.
