@admin , a big thank you to the team of Rose for the superb new vumeters, now you will have to make them more active, they are so shy! Thank you
I agree, also a rose 150 owner.
Hello Herve,
We will check the movements of VU meter and try to reflect it in next update.
Thank you,
Another Rose RS150B user I defo Agee.
Hallo, thanks for the vu meter update!
However it seems that when playing internet radio,
in the level bar view, left and right are switched.
Also, the level bar meter is nice and responsive but all the others are not.
Regards, Bas.
Switched Left/Right of level bar will be fixed in next update.
Also, we’ve checked that the VU meter is a bit slow, seems not moving a lot.
Development team is working on it, I will notice it again when it’s ready to update.
Thank you for your feedback.
Noticed that when listening to spotify the VU level bars move, but not to the music playing. If i pause the music the vu bars keep on going?
Strange!
Regards Bas.
Love the level bars. They run a bit high and of course left/right issue. But I like the look and they are clearly visible also from a distance. Well done
Hi
Has this update for VU movement been implemented or is it still outstanding.
Many thanks
Paul.
It’s added in next update.
Thank you,
Hi ROSELOA,
Would we RS150B users have the level bar meter too?
Regards Matthew.
