Rose Remote and VU Meters
I have turned off the VU meters in settings. Still, when I use the remote, to go to a radio station and press the play (OK) button, sometimes the VU meters will appear. I think this might be a programming error.
@StandardModel
  1. What is your Rose device system version?
    Rose device–>Settings–>System info–>System version info
  2. If you factory reset your Rose device, will the same symptoms appear?
