Rose remote control pairing problem
Hi there I have problem connecting my remote control model GS-R18E( RC850) to pair with my RS250A. When I search for Bluetooth devices it does not show the remote control despite putting it on pairing mode.
[250-260223-001]
Regarding the pairing issue with your GS-R18E (RC850) remote control and RS250A, we would like to suggest a few troubleshooting steps to identify the cause:
  1. Could you please confirm if you followed the exact pairing sequence shown in our official guide video?
  2. Would it be possible to replace the batteries in the remote control with fresh ones and try again?
  3. Are you able to successfully search for and connect other Bluetooth devices (such as a smartphone) to your RS250A?
  4. If your RS250A is currently connected to a 2.4GHz Wi-Fi network, could you try switching to a 5GHz Wi-Fi network and then attempt the pairing again?
Please let us know the results of these tests so we can further assist you.
Best regards,
@vijay181266
Here is the translation for your remote control pairing instructions. I’ve kept it clear and step-by-step to ensure it’s easy to follow.
​Remote Control Reset & Pairing Guide
​First, press and hold the Home button + Back button on the remote simultaneously for at least 5 seconds to reset the remote.
​After resetting, please follow the steps below:
​A. On the Main Unit:
  • ​Go to Settings > Bluetooth.
  • ​Turn Bluetooth ON, then select the Search button on the left.
​B. On the Remote Control:
  • ​Press and hold the Home button + Menu button (three lines) for 5 seconds.
  • ​The Red LED on the button should stay lit.
  • ​At this point, “ROSE RCU” should appear in the search list on your Rose device.
​Quick Tip: If “ROSE RCU” doesn’t appear immediately, try toggling the Bluetooth off and back on again on the main unit to refresh the search.
Ok working now. Thank you
