Hello, I use my Rs 130 with a Gaia and Terminator Plus. Connection is: LHY SW 10 via LWL in the RS 130 CAD USB into the Gaia - via 2 Tubulus clock cables for sync and I2S into the Terminator. The procedure of syncing the clocks and the I2S is applied following the youtube video of Denafrips.
Both clock LEDs of the Gaia and Terminator are on (red light) but if I play tracks above 44.1 kHz (92 and 192 kHz) the signal is interrupted and all LEDs of the right side of the Terminator are off. As soon as the next track is again 44.1 I hear music and a signal is provided and all LED`s are on.
Is there a problem or anything I need to change in the output settings of the RS 130 to play music with higher resolution than 44.1 kHz?
Appreciate any advise to fix this matter. Many thanks to all and best regards Oliver
