Hello, I’ve got Rose RS150 and I’d like to conect him to two AMPLIFIER. Schema of conection:
The main amplifier AMP1 will be connected with Rose via RCA cable. The second amplifier AMP2 is in another room. Distance is 16m. I’d like to connect AMP2 via XLR to RCA Converter cable. The amplifiers (AMP1 and AMP2) will never be used at this same time.
I was read ROSE NOTICE
I have some questions:
- I’ve got Rose Serial No: EBK111AB000150 (year of production: november 2021) Whether the use of XLR to RCA converter is safe ?
- I guess that RCA and XLR analog outputs are active together.
Whether the cable to AMP2 will not function as an antenna collecting interference during use of AMP1 ? - If there are better solutions for how connect Rose to 2AMP please give me advice.
Thanks for reading my post and taking the time to reply. Best regards Pawel.
