Rose RS-150B problem music list in tidal
Hello! After the last update, there was again a problem with saving music to the playlist in Tidal. I tried to synchronize the list as per the previous suggestion but unfortunately to no avail this time, in the window it shows that the communication circle is spinning but to no avail…
Rose server is currently under maintenance. Would you try again after it’s finished?
I guess it will take an hour.
Rose thank you, after a few tries everything is back to normal. Regards…
