Rose rs 250 usb dac/pc
When I connect the PC to the RS 250 USB DAC.
I don’t understand why it doesn’t show the Info display.
At least Bit and Khz.
The USB logo will appear and that’s it. No info.
Example 24Bit 192Khz.
I don’t know if I’m doing something wrong or Rose.IMG_2428
Did you install the driver and rebooted your PC? Don’t think it is driverless for the window version of use.
Also, check if the input is golden in color(activated).
Yes, he installed .
Everything plays without problems.
It just won’t show the info display.
At least technical info about the quality of processing.
I would really like the display to show bit depth and frequency.
Hello @hatoryhanso
When the Rose device is connected via USB IN, it is normal for album cover photos or song information to not appear.
Thank you for the great communication. I understand that it won’t show Album and song title. I just wanted info on the display. Example USB IN 24bit 192khz. Like many DACs in the world that you connect to a PC. So maybe sometime in the update you will show the basic info on the display. I believe you can handle this. You have my support.
