Rose RS130 Home Assistant Integration
I am looking to integrate a ROSE RS130 into Home Assistant. Simple stuff like ON/OFF and input selection.
Has anyone had success with simple integrations into HA?
@wwolfram
The way you said it, power interlock is not possible.
Change to IR Remote
Than integrale the RS130 to a Harmony Remote
Than you should integrate it to Home Assistent or Alexa etc.
Thanks for your input.
For me and my experiences, this is too complicated with too much to manage. I had a harmony and sold it.
The best way for this - is to release the APIs can so folks can integrate properly.
