Rose RS130 standby mode
I have just bought a set of RS130. May I cover it with cloth to prevent dusting getting in when it was in standby mode? Since I found that It still emit some heat even in standby, tks
@Allan
Hello
We do not recommend using a cloth cover over the RS130, but the RS130 will generate less heat than other devices.
However, please be careful as the heat may be completely trapped depending on the thickness of the cloth and the coverage area of ​​the RS130.
Thanks for reply! But is it still cannot cover even in standby mode? I’d actually just like to cover the center logo slot only😅Thanks again!
@Allan
Then, using cloth to cover the center logo slot doesn’t seem to be a problem.
Then good! Prevent dust actually
What is the purpose of stand by mode? Why not just shut it off?
@ThomKat
There were many requests to return the Rose device to standby mode when not in use for a certain period of time. If you completely turn off the Rose device when it is not in use for a certain period of time, there is an inconvenience in that it takes time to turn the Rose device back on.
