Rose RS150 setup and features advice
Hello
I have the RS150 with AK4490 chip
If i may inquire, in the PCM Resampling Frequency section, i have set it to 176.4khz and normal 44.1khz tracks gets upsampled to 176.4khz. However when playing MQA tracks, I noticed this setting does not work. Am i right to say that the PCM Resampling Frequency does not apply or work on MQA tracks
Also in the same section, i see an option called Allow resampling for MQA stream with a box to tick if needed. Any idea on this option?
Thank you for your time and patience
Regards
Ramesh
