Rose RS150 to RS130
I have the RS150 and am thinking of buying the RS130.
Is it possible to put the SSD currently in the RS150 in the RS130?
Of course with all the music on it!
Will I have to do another scan?
Can I also keep my identifiers in this operation?
Thank you for your answers.
@Poune
I’ll answer your questions.
  1. It is possible to use the SSD that was built into the RS150 and used as it is built into the RS130.
  2. When you move the SSD used in the RS150 to the RS130, you need to rescan DB.
  3. If you log in to the RS150 and log in to the RS130 with the rose account you used, you can use it on the RS130 as you used it on the RS150.
