So i’ve just tried playing a radio station using Audirvana and it works on my RS120 perfectly, so it isn’t a firewall issue, but if I try and load a track from Qobuz it won’t load?
I have “Rose - OC” selected which is correct, and you can see my DAC is recognised fine (bottom right).
Audirvana Studio is running in my NUC whcih is on the same network as the RS130.
