Roseloa,
Iâve given you this information and asked several questions in this thread. May I please have a response.
ROSEHAN
16d
Hello Rosehan,
Does this work? Iâve tried with my RS 10 and the Windows based AudirvÄna can âseeâ the HiFi Rose RS 130 but after a few minutes the AudirvÄna reports that it is not receiving any information from the RS 130.
Yes, the DLNA server option on the RS 130 is enabled.
I have checked firewalls on the Parallels/Windows and all are open and not blocking any transmission from the Rose so far as I can tell.
Is there a tutorial or do you have any suggestions as to what I can try next?
StandardModel.
1 Reply
Reply
ROSEHAN
15d
A digital media server (DMS) stores content and makes it available on a network. A digital media player (DMP) can find content offered by a DMS on the network and play it back.
Itâs my impression that the Rose device can serve as a DMP for AudirvÄna on a remote computer acting as a DMS. Am I correct?
If I am, how are music files displayed when coming from the AudirvÄna server to the Rose as a DMS? Where do I look for the music?
Iâm running the AudirvÄna and it shows that itâs connected through kernel streaming to the HiFi Rose RS 130. The Rose says that its DLNA is running. Now what? Itâs my assumption that the music files displayed on the AudirvÄna should show up under the âMusicâ tab of the Rose. If that is how it is intended to work, it doesnât seem to.
1 Reply
Reply
ROSELOA
14d
Whatâs the OS of your PC?
Windows 10, 11 or MAC?
Reply
14d
I have a Mac Studio Operating System Sonoma 14.1 Operating also on the Mac is Parallels to emulate a PC.
This PC runs Windows 11.
Audirvana is running under Windows 11
StandardModel.
Reply
Basstech
9d
RoseHan and RoseLoa can You read this topic and check how it looks like on Your device? The last problem with playing gapless DSD.
Audirvana â 7 Nov 23
I see, so gapless with PCM is working properly but not with DSD, can you contact them about this manner and check if they get the same behavior on their end? I do not have the unit here at the office so I canât reproduce this on my side
Regards
Reply
3d
Iâm bumping this because the questions have not been answered.
ROSEHAN
12d
With HiFi Rose (I have an RS 130) acting as a Media Renderer (DMR) I believe that means that the RS 130 will find a DLNA Digital Media Server (DMS) provided they are both located on the same network.
I also see that AudirvÄna lists HiFi Rose as a device that will act as a DMR with it acting as DMS. So, when I install AudirvÄna and the RS 130 on the same network the RS 130 should see the AudirvÄna automatically and act as a DMR for the DMS.
When I had my prior Streamer, a Cambridge CXN-V2 the DLNA function worked exactly this way by a) displaying all DMSâs on the network and allowing you to pick one and b) once a DMS was picked, displaying the content on that DMS ie, music files for you to pick and play on the CXN-V2 acting as a DMR.
My questions:
- Why doesnât the RS 130 display some indication that it has found and is connecting to a DLNA server on the network? Am I missing something?
- Once there is some sort of confirmation that a DLNA server is found, how does one select âseeâ and âplayâ the content from the AudirvÄna DMS on the RS 130? I see no way to do this.
I see that others have made this work partially by having a third party program but this should not be necessary. The only option I see with the Rose Software is to âRun the DLNA softwareâ or not. Where are the rest of the necessary choices to select a DMS and then select and play the DMS content?
Is it possible that the HiFi Rose is a DLNA Renderer ONLY and does not act as a controller as well? This would seem very odd because, if so, it makes the renderer function almost useless.
Please help me understand exactly how the DLNA program on HiFi Rose works as a DMR and how to play music from the DMS through it.
Reply
