Rose RS451 audible hum
Hello @burki ,
I would like to ask about the hum noise issue related to the RS451.
Based on the posts you shared, it appears that the hum noise is coming from the RS451 unit itself rather than from the speakers. As you are very familiar with audio equipment, you will know that hum noise can be caused by various factors. It may be due to a fault in the SMPS or transformer inside the product, but it can also be caused by environmental factors including ground loop.
If the internal SMPS or transformer is defective, replacing the component would be necessary to resolve the issue. However, sending the product back to the dealer can be quite inconvenient.
For this reason, I would recommend checking the surrounding environment and grounding first before sending the unit to the dealer as a last resort.
Would it be possible to connect the RS451 directly to a wall outlet rather than through a power strip?
If there is a dedicated outlet with no other audio or network devices nearby, that would be even better.
Best Regards,
If you go to YouTube there’s an audio reviewer in California who is reviewing a set of Orchard Audio mono blocks.
He complained of a slightly audible hum when there is nothing playing… and his ear is next to the speaker.
Leo the founder of OA told him to get a device to help filter the power. (You can watch the video to see what its about. You can search for Orchard Audio review to see this. I think the reviewer is Ruiz.)
The point here is that if the issue is w the incoming power… going over to a friend’s house may not solve it. Most likely its going to have the same issues unless your friend lives on the other side of town and its a large town / small city.
I’ve been lucky… for me… I lived 20yrs a block away from the local sub station.
Now I’m less than 1/4 mile from the local one, and in new construction.
So I’d say it could be the power, not the unit. Something to check out.
I have a test unit at home and I’ve noticed a background noise when a song starts at a very low volume (a kind of pinkish sound). If I pause it at that moment, the noise stops.
I’ve also noticed it when using streaming platforms.
Perhaps doing tests so close to the speakers isn’t helpful?
I’ve also found that the equalizer isn’t working properly (it works even worse if you use the app).
My unit does not have the transformer hum.
And I almost forgot, the VU meters freeze after a few minutes
I’ll turn it on again today to see if it works better.
Update: I played the same song on a CD player using a coaxial input and I don’t detect the pink sound.
Update 2: Detected the same sound (as if played from a tape) with songs from the hard drive (perhaps a little less)
Update 3: When playing video files, (from HD) the ā€œpinkā€ sound is not detected.
Update 4: It appears that the VU meters start working again by pressing the ā€œreloadā€ button.
Try with an external battery like Bluetti or ecoflow … so you ca isolated the problem
A test unit? Ok…
So what does your set up look like?
Where do you live? Quality of power ?
Then what does your setup look like?
What does your internet connection look like?
Hi !
My setup is a preamp and power amp, using the RS451 as the preamp.
I live in Spain… and my power quality isn’t the best, but it’s not the worst either. I use a filtered power strip with decent Isotek cables… sometimes I use a Bluetti battery to power the equipment… I detect pink noise equally well with the battery or direct AC power.
My connection It’s very fast (fiber optic(, and the equipment is connected via Ethernet cable.
Filtered power strip? Sounds like surge protection only.
And you hear this even if there is nothing plugged in to the unit but the power cable?
I’d say send it back and exchange it. Something isn’t right.
Purchased my Rose in early Jan 2026 from Peter Tyson UK. Just reading this thread ive stuck my ear right up to the case - witin 3 inches and my 451 is absolutely silent, can’t tell if its on, off or in standby… apart from the display of course ! Superb player . I part exchanged my 150B for this and with 3x isoacounstics Bronze and a slab of granite under the pucs its sounds , in my opinion as good as the 150B, in fact would say some nuiances of music are actually better ! Also have some Dan Clark Audio Noire X’s plugged into the 4.4 and its the dogs bllx …
That’s why I said to send it back to dealer as a warranty repair.
It should be dead quiet.
@KJRichards
If I understand your symptoms correctly, are you hearing an electrical or humming noise from the RS451 when it is powered on or in standby mode?
And is that the reason why you exchanged your RS451 for the RS150B?
I bought a silver RS451 which had a noisier hum from the transformer, took it straight back and exchanged it for a black unit ( apparently approx 10 black units sold for every silver unit so more likely to be later production ) this new one hums, not as loud but still annoying in a quiet room, could this be anything to do with UK voltage?
@Ziggy
A very slight noise can occur due to the flow of electrical power.
However, if the humming noise is noticeably loud, it may indicate a defective transformer and could require service or repair.
Please contact the distributor in your country so they can check whether the unit is operating normally.
Electrical power can vary widely. So yeah it could be the quality of the power coming in… however see what Rose had to say…
There’s a couple of UK audiophiles like Tweakerman who have done some interesting things due to the quality of power coming into their homes. Even here in the states, we can have issues depending on the distance from the switching station, age of the lines and then the wiring in your home.
A simple test… if you have a friend with some form of line conditioner / battery backup see if you could borrow it. Even test running the unit off the battery power… That would confirm the issue isn’t in the Rose unit but the quality of power coming in to your home.
Good luck.
@Ziggy
As @Smegel mentioned above, power quality can vary significantly depending on the region and environment, so the quality of the incoming power could certainly be a possible cause.
Please check this and let us know the results.
If you have any other questions, feel free to contact us at any time.
Hallo ROSEHAN
I wanted to buy a Rose RS451.
We tried 4 devices and all 4 hum. The hum is clearly coming from the transformer, even if only the power cable is connected and turned off, it hums.
If this cannot be fixed, I will not buy the RS451.
In Switzerland we have 230 volts.
I’m not the only customer who has the problem.
My dealer has three other people who have this problem.
Apparently they had contact with Rose and her statement is, "We don’t know the problem.
I suspect that transformer fastening or casting quality is not optimal. Poor fastening or insulation seal can be the problem of the charge
Greetings from Switzerland
Remo
@Remo55
Due to the characteristics of transformers, it is not possible to eliminate transformer hum completely.
As a general guideline, if you cannot hear the transformer hum from approximately 1 meter away from the RS451, we consider the unit to be operating within normal specifications.
Even when only the power cable is connected and the unit is turned off, the transformer is still supplied with power. Therefore, it is not possible to eliminate transformer hum entirely.
Hallo ROSEHAN
Thank you very much for the answer.
Remo
In my experience transformer hum in audio devices is mostly caused by DC component in the mains. It is not easy to pinpoint whether DC is present since it may drift according to time of day and use of other appliances. Also changing the grid (like moving the unit from your home to the office) also may not work since DC may be present at both locations.
Switching mode power supplies are generally immune to DC offset. A true 50 Hz ā€˜linear’ transformer like the one in RS451 is very sensible to DC offset.
I have no solution to check the issues but trying to power the device in several locations may help to find the cause of the problem. There are also DC offset mains filters but their efficiency will of course depend of the design.
I also have a Rose RS520 and there is no humming at all.
For me, the Rose RS451 issue has died.
I will not buy this device.
It’s a mystery to me how a device that’s completely turned off can hum.
I will make no further comments on this topic (RS451).
I have an Audio Note system, nothing hums.
Remo
P. S.
I have now purchased the Rose RS250A.
There are other possible issues besides the power coming in…
What are you using to connect your RS451 to your amp and what amp are you using?
For example… it could be your RCA interconnects. Not that I’m saying go out and buy crazy expensive interconnects. But the Amazon basics or Temu/AliExpress cables could be the issue.
Can you borrow a pair of really good interconnects to try them out?
