Rose RS451 HDMI connection
Hi everyone,
I´m interested in upgrading my streamer to the RS451, but i would like to know if it can wake up and turn off with my TV via HDMI connection.
Any info would be appreciated.
regards,
Rui
Hi @RuiC
There is an RS451 on/off function when turning the TV on/off via the HDMI eARC Port.
@RuiC
If you see the picture above RS520 supports eARC, allowing power interlock when connected to a TV via eARC. Volume is interlocked by default, and if you turn on the corresponding setting, power will also be interlocked.
The photo above shows the RS520 input/output panel, but the RS451 also supports HDMI eARC, so it supports the eARC power interlock function as well.
Awesome, thank you very much.
Thank you for clarifying.
@ROSEHAN does it also have pre-amp via digital (coaxial/toslink)? Or only via analog RCA/XLR?
Best regards,
Rui
@RuiC
Volume control (pre-amp function) is also available through the digital outputs (coaxial/optical).
On the RS451, go to Input/Output Settings, then click the small gear icon in the Output section. There you will find the Software Volume Control option.
Please enable this feature.
Below is an explanation of Software Volume Control:
Some USB DACs support UAC2 volume control, while others support HID volume control. In this case, when you adjust the volume on the Rose device, the volume command is transmitted to the DAC to control its volume. If the DAC does not support this feature, you can enable Software Volume Control in the USB DAC settings within the I/O Settings menu, and then adjust the volume through the Rose App.
Caution 1. Software Volume Control cannot be used in Native DSD or DSD over PCM mode. It is applied only after switching to DSD-to-PCM mode (up to DSD128).
Caution 2. For digital output, MQA Stream is supported only when the volume is set to MAX. If the volume is below MAX, MQA Stream is not supported.
